Im cutting a name in a cutting board.
Wondering if using Offset cutting tool path is worse than Raster X Axis?
I am very familiar with 3d printing, built many voron 2.4’s yet this stuff seems like a foreign language some times. Im taking material away not adding it.
So, in my mind, actual CNC machines can do Offest or X Axis / Y Axis depending on the quickest path, however, a CNC is way more accurate than our X-Carves.
I got my gantry level, however, sometimes the bits leave imperfections in larger cut areas say a 2" x 2" square cut .1" deep will leave some lines behind that I have to sand out to get a “flush smooth look”
I am thinking that X Axis for the first cut makes sense versus the “Offset” option.
Any ideas?
