Loving everything so far with Easel Cabinet Maker, but am I missing a checkbox or dropdown for removing the drawer fronts from an operation rather than doing it manually and nesting again? Reason being the carcasses and drawers have been great off the CNC, but I still do my drawer fronts on shapers and saws.
Thank you!
I Also have the exact same question for the same reason. Have you found a solution?
There is a checkbox to make them out of a different material, just pick some weird material and then ignore it
I think it is also the same material used for doors, so if you want doors and not drawer fronts, you may be in a pickle, but I would venture to say you are probably doing those manually as well.
