Ever set your safety height low enough so you carve time is faster but forget about the clamps that the bit winds up running into at the beginning/end of a cut?
Now you can set two separate values, an Origin Safety Height and then the standard Safety Height.
When we adjusted the safety height prior to this change it would always revert back to the set standard after the project was ran. Is this a change that remains until we change it again or does it revert back to the set standard each time we run a project?
