Hello!
This is my first post on this forum.
My problem is simple and i am wandering why i can’t find any traces of similar issues online.
I want to prioritize paths: cut inner parts first and outer part - last. All in one take without stopping the machine.
Say, i have a detail to cut which has a lot of inner paths and an outer path (shape). Naturally i want the inner parts to be cut first, as i imagine material is more stable and secure while it is one piece (of course there are tabs, but there’s lots of stuff that go wrong, like incorrect material thickness or they just can snap).
At the moment i am solving this in very shaky kind of way, i just delete the outer path, cut my inner parts, then (cmnd+Z) getting my outer path back and delete the inner paths and cut the shape. I believe there should be more efficient way that allows to do this in one take.
- i guess it could be done manually by editing g-code, but getting into learning it is not on my list yet. (this is one of the reasons i chose Shapeoko & Easel, as it allow me to work very fast and easy without difficult programming, i cut directly from Easel).
- i also aware of the new two stage carving feature, but i guess is not really my case. (It could be though, if that would work like this - select path/choose the right bit for that. then i could just have set both bits to the same size and cut my design in two stages without changing the bits)
Would be thankful for your thoughts and possibly solutions.
My setup - custom made Shapeoko 2 (1000x750), Makita RT0700, MacbookPro. I mostly work with plywood.
Thanks!
