Hi Everyone,
I have an XCP and have trouble pausing and resuming . When I hit pause ( inside the easel app not the x controller box ) mid carve The bit goes up and turns off…I hit resume ( inside the easel app ) and the z axis goes down but the bit doesn’t turn on and I need to abort the carve. Its a real PITA.
I did get it to work once today by using the x contoller to pause ( but then the resume button doesn’t work on the x controller ) so I hit resume in the easel app and it starts up half way in its descent from the z axis )
yes I could do this operation each time but I may forget and snap a pricey bit.
***edit : I cant get the x controller to pause / restart the bit anymore…I’m currently turning off the x controller and replugging it in after 10 minutes.
****edit : resetting the spindle after 10 minutes worked !
*****edit : back to not resuming after pause.
Thanks,
Tom
