Time to find a cheap keyhole bit!
I know aspire has a keyhole maker in the little add on section does v-carve have that is where the Celtic knot creator is … that’s what I’ve been using .
Edit : there called gadgets
Here’s the link
Lowes or home depot
Peter Pasuello has gcode and an article that talks about Keyholes
Maybe this could be of use:
http://www.nc-corrector.inf.ua/index_EN.htm
There is a function to automatically remove line numbers. Or, add if you wish plus several other neat features.
Successfully exported gcode from Easel, manipulated the file and imported. I did not run a test carve but it imports just fine.
A big shout out to you Phil. Thank you for posting this key hole g code. I have never done anything like this at all using g code. You made it so easy. I just made a copy of the file. Zoomed in to determine the direction of the hole and followed Easel instructions to carve. Not ever having done this I did a test carve with a small piece of foam. It worked perfectly!!
Nice carve what did you use to finish it?
Lol. I’m going to hang it on the wall just as it is
There you go, my latest project hanging in my shop using phil’s G code key hole program. Thanks Phil. I could never have got this to hang on the wall without your program
I am going to start using the key hole program on many of my projects go forward
A work of art!
What art gallery is this located At?! I’d love to take a look at it! The edges are so fluid and just speak to me.
The surface detail is incredible! Must of used a 1/64" dbl straight flute bit!
Really nice! Solidworks then Meshmixer?
Freaky!
Uhh, Phil. This is supposed to be a family-friendly forum.
Damn this is really nice! I wish I had half the amount of patience as you do so I could Learn this stuff!
@PhilJohnson there is no such thing as a cedar board with only one knot… you got the fake stuff “ceder”.
