Where did u get that fancy moon texture
looking good so far. so when you are tilingā¦ do you have like an inch of overlap or does it pick up at that center line?
I would think it would have overlap but that is why I ask
wow. quite amazing. I really thought it would be more than that.
You sir are amazing.
Excellent work! So it looks like youāre a tile master now too. Iām curious about your method of work. It looks like you do a milling pass first and then cut your letters? Do you re-zero your Z axis after the milling or just set your start depth to the new surface? And I assume you use a large cutter for the milling pass on a project this large?
What the diameter on your v bit? Inch, inch and a half?
Looks great Phil !!!
Iām constantly amazed by your skills, Phil. It looks amazing!
It will probably turn out like everything else you do. Amazing!
Like I said, amazing!
Looks great! You can paint. Lol
Gorgeous!
Maybe a golden oak or light stain on the cabin to bring out the grain and give it that aged cabin look?
There needs to be a ādouble likeā option.
Iām always amazed at how the black in vcarved letters really makes it pop
I have STL files to carve Japanese girl to help for Painting, if you interest.
How long is the Finger.
That is great work Phil. As always.
Wow!
How do you get such a crisp finish between the lettering and stained wood? Do you need a mask or something
Phil, did you create that STL yourself, or find it someplace? Iāve checked 3dmag.org, yeggi, thingiverse etcā¦ and canāt find any of those ā¦
Awesome thanks, birdhouse, nose, pick etcā¦ werenāt returning anything goodā¦
