Is it possible to use a Photogrammetry software to capture a real life object and then cut it out in 3D on the XCarve Pro
Sure, if you can generate a decent STL from your software.
Definitely… any 3 axis cnc can carve 3d reliefs… you just need a good software to generate the toolpaths…
I use carveco maker (normally $15/month), and there’s a 90 day trial in here that lets you save the gcode and you can send using Easel if you like…
