Planing Uneven: Stepover?
Planed a board today using a 3/4" bit: 60 ipm, 9" plunge, .01 DOC. I planed the wasteboard recently so it’s flush to the machine. How can I plane my boards so they don’t have these slight ridges? Decrease stepover % ? My default currently is 40%.
Setup: DeWalt set on 1, 30 min x axis mod.
x
What type of bit did you use?
Photo 1: Looks like my z axis is square?
If you check out this video… is the only way to deal with this by doing the steel bar mod? I did the 30 min one, but may that’s not enough.
Oh, thanks! Yeah, it’s clear in the back and not front. I think the Dewalt weighs the whole thing forward. I’m going to try to adjust the v wheel nuts, and the slides / mod to compensate for that. If not, I guess I’ll need to do the steel bar mod. :confused:
There is play. If I lift, with some effort, the z will move up and down. I’m trying to figure how to get rid of that, but don’t quite understand how to fix it…
I had to shim the top of my Z axis out to square it up with the wasteboard:
Yup, that’s about .100" of business card stock. It’s amazing how much of a difference the weight of the 611 made.
Good point.
