Please for the love of god put a "Parking Spot" button on the interface
Every single cut to place the material and remove the material the machine is in the way. This takes valuable time away from the user, please place a button that moves the machine to a specified location. This is a major time suck when trying to burn through material, like seriously please help
Thanks
In Easel Pro, I believe there’s already an option to park the gantry past the piece being cut. You have to choose it from the end of cutting screen.
However, I don’t use it because it’s more aggressive than I need. I usually do the following things after a cut is complete:
  1. Switch to 1" mode for Z, and raise it twice, so I can remove the dust boot.
  2. Type a value into the “Custom XY Distance” that’s further back than my piece, and move just the Y axis back.
This is pretty quick, but also makes it easy for me to undo when setting up the next piece, since I can just reverse those two steps. I did this a lot when cutting out all of my shop cabinets earlier this year, moving through about 20 sheets of plywood.
