The plunge rate is now with the beta tool path optimized to reduce time on Z-axis movement, especially noticeable when doing tabs. However, the pull up speed could be much quicker than plunge speed. Would be easy to implement?
Plunge speed = downward speed, pull-up speed = much faster opt./max Z-speed.
I wouldn’t know either
3D cut i think ?
if the rounded bit is milling folowing the form, and “climbing” (in the z axis…) not easy to explain…
like in a finish pass…(depend the gcode…)
well it will climb too fast !
let’s make 2 profile:
normal with up speed > down speed
3D with up speed = down speed
edit: thoses speed aren’t set in the program who do the g-code ?
if yes my message is useles…
but what about in the future if easel can 3D easier !
As long as the milling speeds is differentiated from plunge/extract that shouldnt be an issue - but I understand what you are thinking.
I noticed this last night (cutting a few deep mortises). A simple setting button next to plunge rate would be really cool. Let’s call it “extract” or “retract” rate. I bet those Easel guru(s) could do this on their lunch break.
It should not affect 3D milling if the up speed is increased in operations that only consist of moving the Z axis.
I’d like to see this implemented.
Thanks for the feedback. Let me discuss this with the team.
In addition to this, would it be possible to add a retract height option? Useful if you need to clear clamps or fences on the way back to “home” …
Specified under Safety Height in Easel. (default is 3,8mm)
Easel → Machine → Advanced
