I´m about to do a sign with pocket cutting.
My idea was to use a 60 or 90 degree bit for cutting the letters
but how do I do to cut the rest of the bottom ?
Do the two stage carving. The first bit will be a roughing pass. Use a flat bit or end mill. This will clear most of the material away. The detail pass will be the v bit.
Thx Phillip
I´ll try that and give you feedback
Are there a way to have the z axis not to move while I change the bit
Look for this thread you also need to flip some dip switches
