In creating this sign I used these settings and all seemed fine however for the chatter and visible lines. The chatter was somewhat remedied by doing the usual techniques of belts, v wheels, tighting bolts , etc. I changed the settings by slowing down the feed rate to 60 ipm from 80. This still didn’t seem to help all that much with the x axis.
The pocket on the sign is leaving lines. The pocket is done in 2 passes with a final pass as shown in the attached picture.
I checked the z axis and found it off by 1/16th give or take, I also noticed some movement in the axis. The movement looks as thought the wheels ie. x carriage is not tight against the rails.
I do find at certain pocketing or thru cut if the x maker slide is too high and the bit is fully seated in the router the lower wheels physically slide off the rail causing the whole assembly to shift and leave chatter and bad surface marking.
Fixed the maker slide issue with all the wheels. I ended up retighting them with blue lock tight and made the proper adjustments, all is secure. I did a another trial run and it helped but not cured.
I did a check of the levelness of the table and found it lower on the right side of the table. Thinking I might add a sacrificial waste board and flatten this out .
I really appreciate your time and effort in these videos. From the beginning of my purchase they have come in great use. Thanks again and I’ll check it out tonight.
I’m always glad to hear they’re making a difference. If it helps, I’m trying to do a series of quickie videos every couple weeks to address random things related to the X-Carve. The video coming out tomorrow at noon (mountain time) is going to show how I went from SketchUp to SVG to Easel.
