I’m just getting started and am wondering how to determine pricing for products created on my X-Carve Pro. I was going to start with a local pub and make custom Flight boards. 3 1/2" x 14 1/2" with a handle and 4 holes for the glasses. Using inexpensive wood, how much should I charge for something like this? I really don’t know how to come up with rates. Thanks
Most of the time people will have something similar to this:
- Material Cost (if the customer is not supplying material) - The cost of the material with any markup you are going to place on it.
- Design Rate - The hourly rate you charge for the design work it takes to create the work.
- Shop Rate - The hourly rate for yourself to be actively setting up, tearing down, or finishing the material.
- Machine Rate - The hourly rate at which you charge for the machine to be actively working on a project.
Of course, everyone has their method, but this is about as simple as it gets. You can just provide the customer with an NTE Cost (not to exceed cost) or a flat rate.
It is really up to you…
{:0)
Brandon R. Parker
How would they be customized?
What wood?
These matter. But using cheap pine (I wouldn’t recommend), you could make 5 or 6 per 8’-1x4 board, assuming some unusable parts. If that’s purchased in bulk, you’re looking at less than $1 in material per piece. Using slightly better wood, the price jumps unless you have a supply. You can buy plain, finished flight boards in bulk for $4 a piece. Can you beat that? If it’s the customization you’re selling, is it cheaper to buy from a supplier and customize? That will all factor in.
