OK, So I designed a sign & grabbed a bunch of grapes from the Pro Library.
I know that the graphic will show up or not show up on the preview screen depending on the size of the thickness of the lines and the graphic and the diameter of the straight bit I select, but with this one grape graphic, it will show up or not show up on the preview screen depending on the angle of the V-Bit I select. (15* and it shows up, 45* and it doesn’t)
Bug in the library?
can you share the grapes so someone else can see if we get the same result?
Hi @MichaelValentino,
It looks like you set the cut properties on the grape bunches to Cut inside. If you switch to Clear out the pocket you can see the shapes be carved with all V-Bit sizes.
I guess I thought that since I’m cutting with a V-Bit there would be no minimum bit width that couldn’t be cut or displayed, since the bit width of a V-Bit is essentially “0”.
I’ve never see this before.
