I haven’t had any more problems…there does seem to be a fine line between too tight or too loose, at least on my machine.
I currently have nylon locknuts behind the eccentric nuts but I have bought eccentric spacers to replace the nuts. Just waiting on finding the time to do it.
someone can help me?
when I draw a circle, the end of the line can not be closed
sory, my english is bad
Stan, in case you’re still around, I thought I’d ask you about your v wheel tension… Can you move them with one finger?
Some of the wheels i can barely move with 1 finger and others it takes 2. I know they should all be the same but it is working good like it is so… I also know that really doesn’t help you
I’m having the same issue in Easel. It also appears to get worse if you carve several circles back to back during the same carving session. Very frustrating because I don’t want to have to restart a carve for each circle to cut several circles out of a single piece of material.
