Problem solved cnc stopping mid carve
After a year of frustration some one in our forum suggested l purchase a usb cable with ferrite beads so I did and that finally solved the problem of my cnc stopping mid carve (see attachment) Thank You.
have the same problem I have ordered the cable and hope it works. THANK YOU!
Larry I want to give James Walls the credit for suggesting the filtered USB cable that solved my many months of frustrations. I tried everything but the kitchen sink, and in the end it was a simple filtered USB cable between my laptop and CNC controller. Hope this works for you. Let us know.
Thanks
Jim T.
I had the same issue right after setting mine up. I put ferrite chokes on everything and grounded the chassis to the building ground rod. No more issues!
