hi many thanks for all your answers yesterday you all solved my problem
the next problem i have is the machine will not confirm work zero
I hit the x button it moves around 1mm then thats it and will not move again until you switch the machine off then on again it must be really something stupid im missing any help would be very helpful the problem is i have learning problems and have been trying to set this machine up thank you again bryan
Did you happen to home the cnc prior to this issue?
If you have homing active on the cnc, then it will be alarming for moves without homing on initial startup.
What is the $22 value?
