ok so here’s the deal I added the 2.8 laser from jtech and so far I got the install to go through. however I’m having problems getting the actual laser to work with easel. at the present time I would just like to burn words into wood later on I will get the picsender and picengrave software when I see fit however I just want to do this for right now. I also have vcarve desktop and will be looking on how to get that up and running also. I know there is a post processer with this and I have that installed also.please help me out asi have spent a couple of days trying to do it. I know its memorial day today other wise I would have called jtech already. heres what I don’t understand
If you bought the X Carve with the electronics included (like most people do), then they shipped an Arduino UNO with GRBL installed already. You either have GRBL version 0.9i or 0.9j which Inventables branched from the main GRBL github development site. Both of these will work fine for most applications, but will leave a slight delay when trying to engrave pictures with PicLaser software. If you just want to cut things and do black and white engraving, then you will have no problems.
To turn on and off the laser the command is:
•Laser ON: M03
•Laser OFF: M05
If you want to use power control for the laser (via Pulse Width Modulation) the laser command is:
M03 SXXXXX
Where the “XXXXX” is a number between 0 and 10000. So, some examples are:
•Laser ON 100%: M03 S10000
•Laser ON 50%: M03 S5000
•Laser ON 10%: M03 S1000
•Laser OFF: M03 S0 (or M05 will work as well…)
where do I put these commands in to get them to work how do I get them to work with out burning it into the wood and how do I find my corner without burning my fingers
I have read that and I’m not sure where I’m getting with it. I don’t understand all the lingo either much less where to put it in at. I got the post processor to work with vcarve however it doesn’t do the whole design and burns holes into the wood
ok so heres what I have been able to do. I made this in vcarve desktop and I’m unsure of how to get rid of the dots and make the laser stop when moving elsewhere
Vcarve generates the gcodes for spindles not lasers, so it sets a S command to turn on the spindle with PWM at the beginning of the file, then rapids to the place to start and that is causing the burn line with the laser. Any hesitation of movement when the laser is on will cause the burn dots.
You may want to consider using Inkscape and the J-Tech laser extension for your vector engraving projects. It will generate the gcodes properly without having to do any editing. When using a laser, higher accels are required for the X&Y axis and that will eliminate the hesitations/dots you are getting.
I believe it only traces pics for vector engraving, but I never tried it so I can’t give you a definitive answer. I only use PicLaser or PicEngrave Pro 5 for raster laser engraving photos & logos.
The Tutorial for PicLaser is in the Help menu and in PicEngrave Pro 5 the Tutorial button appears after loading an image. The Tutorial in PicSender is available by selecting the Info button.
Are you talking about a gcode file from Inkscape? If so, I don’t know if the J-Tech Laser Extension generates the gcode compatible with Easel for streaming. We don’t use Easel or Inkscape, so you may want to read these gcode requirements for Easel.
You don’t need to flash the J-Tech LaserMode grbl 9g to your UNO if your are vector engraving by turning the Laser on/off with S commands. But it is recommended if you are raster engraving photos with varied intensity with your Laser.
The J-Tech grbl will run X,Y & Z commands for a spindle but will not run arc commands or G00 rapid moves. I recommend you copy/paste your original grbl settings to a text file before flashing the grbl firmware to your UNO. The grbl settings will change and you will have to change the majority of them back for your X-Carve, so it’s important you back them up.
well I did that once already and didn’t save it now I have the grbl file cause I found the orginal hex file for it. it think I should be able to do both but it looks like I will have to buy another machine to do both instead of flashing the grbl twice a day
so I’m trying to get picsender up and going and from what it seems like when it asks me to save my grbl settings by clicking on the yellow button nothing happens and I’m not sure where to go from here
