Does anyone know what program is able to put words together so you can carve out all together?
example but want my own fonts.
Example
http://www.stevedgood.com/stencil/
In Easel you can achieve this by first typing in the word/name, then use the Xploder-app to break the letters into individual objects. These can then be combined as seen fit, in combination with a rectangle your example show.
Your particular example seem to have a larger “base” where the letters connect, and a “3D” contour is used to visually separate them.
Thank you I well give that a try.
BTW - set each letter/objekt as Fill and once placed choose Combine. You now have a single object where you now can choose as Outside/inside or Fill.
