doing new carve centered design on easel finished carve bottom and left border same distance but top and right side are the same but different than bottom and left any help would be appreciated.
There’s 2 ways to fix this issue.
- Recalubrate the movements, but if you do this you’ll need to record the data because if your browser cache gets cleared, easel will prompt you to redo the machine setup and set them back to the stock defaults.
Or - Leave calibration slightly out of spec and instead Use center as the origin (0,0) positron
Here’s videos showing both fix options…
