Proper oil to use
What are the maintenance recommendations for this machine? What type of oil should be used and how often and where should we oil the machine? I see these oil pictures at various locations on the machine but cannot find any maintenance recommendations on their website.
i would recommend sewing machine oil or any lite 3in1dont leave it puddled or dripping wipe it off with a rag and let it go dont cake it on…
Yes… Any official recommendations from Inventables for the proper lubrication to use and the recommended interval? I’d love to be able to keep my machine happy and in smooth operating condition.
Why not use the wd40 dry ptfe spray? I use this on all my tools with moving parts and never have a problem with sawdust sticking to it.
Since i had used PTFE dry lube before I had also suggested this to a Pro owner in the past, but was quickly directed to a few reputable linear bearing manufacturers who say to not use PTFE dry lube on bearings, but only on friction surfaces…
Had i not been informed and done my own research after the fact I probably would have put PTFE dry lube on the bearings as well.
As it turns out this is the first google result …
That same link goes on to say>
  • Light loads and high speeds do well with a machine oil or low viscosity grease.
  • Medium loads and speeds do well with NLGI 1 or 2 grease
  • High loads may require a grease with an EP2 additive. The EP is Extreme Pressure and uses special additives to prevent the grease from breaking down under high pressures. This type of grease will give the steel shafts a dull appearance.
So @JeffreyJones there are some options here, I would say, that in comparison to other applications of linear bearings, a CNC is considered a light load and machine oil (or 3in1 oil) would be sufficient.
@SethCNC Thanks for this information, I have never had a problem but I start looking into changing up what I use.
I use Valvoline Heavy Duty Crimson Multi Purpose Grease. Do not use the dry lube
Why not use dry lube?
The dry lube does not provide good lubricant to rolling bearings including linear bearings. Dry lube works well for sliding movement
Check out my post above, with the photo of linear rail manufacturers recommendations and reasoning
I reached out to INVENTABLES and they told me to buy WD40 Lithium Grease. They said to apply it every 6 to 8 months.
