PSA: Don't forget to tighten your collet after changing bits
This is what can happen if you only finger-tighten a bit into the Dewalt 611. It took less than 6 seconds to reach the e-stop; this damage happened fast.
I was using a 1/4 inch carbide bit and blue tape/CA glue as a hold down. The bit slipped down and bit too deeply, causing the tape to release from the wasteboard.
The work piece rode up the bit and struck the Suck-It dust boot mount, shattering it. Luckily I did not have the boot in place for this cut. The oscillations also shattered two of my v-wheels on the z-axis.
Splinters and broken chunks of wood and plastic went everywhere. I was wearing a full face shield, and was leaning over watching the cut when everything went pear-shaped. Quite a bit of debris hit the shield.
My x-carve is going to be out of commission for a while. Better the machine than me!
One good thing came out of this… I can now cross-section this inlay and see how well the pieces are mating.
Props on finding the silver lining
is that wenge?
always sad to see a nice piece of wood get degraded to the scrap bin
Wow… Glad you are ok. That could have been real bad.
yes, it is wenge/paduk.
I have extra material stocked in case of mishaps, but I only anticipated damage to my stock, not the x-carve itself. All is well though, I’ll just use this as an excuse to upgrade to a linear z-axis :smiley:
