I’m using the Flights of Ideas extension to export SVG’s.
I’ve try two different versions of that plugin and cant get either to export. do you have link to where you got yours? Thanks
I don’t remember the exact site, but I found this download link on my computer: https://github.com/simonbeard/sketchup-svg-outline-plugin/releases/download/0.9999999/flightsofideas.rbz
Didn’t share it publicly Robert
Hopefully this one is better.
Take it from someone who has lost a digit on a table saw (I’m often referred to as “Frodo”), the DiResta push stick design is much safer than the classic push stick like what Zach posted.
Less degrees of freedom = more safe. If your push stick can articulate, it can let your body parts slip and slide around into the No Go Zone. Bad things happen at thousands of RPM’s (which is fast).
The main notch for the push stick should be below the centroid of the triangle (for most of the push) and there should be another notch right on the front tip (for the very end of the push).
I knew you were kidding… It only took 45 seconds.
I would like the svg. version… of the ‘correct’ file of course
Thanks!
Here is it in Easel:
Here’s one that I use…
Sorry I forgot…hate when that happens!
I got the design idea from Steve Carmichael. Check his youtube channel out https://www.youtube.com/watch?v=SokWzZcXOpQ He makes some cool stuff.
That is an excellent design, thanks for sharing
