I am looking for the cut out design for a quarter board with the carved in edge. I can do the lettering but need the pattern for the ends and edges
If you’re using easel there are some in the pro design library (the apple on the left side)
The quarter round carved in is a bit tougher in easel since it doesn’t do real 3d, you can use a box core bit and sort of trick easel to make it work and get your desired results, it’s a bit of a hassle to get the hang of though
