Hello,
Complete newbie here. I have a 3018 and I’m working on my first test. Actually 2nd test. The problem I’m having is the the spindle stays about 1-2 inches above the wood when it’s carving. I’ve run through all the tests, everything looks fine, I hit carve then this problem.
The first test worked. I just did a quick very thin cut into the wood so I can make fine adjustments with the measurements and now this issue.
I even tried doing it over in a new project thinking i changed something and just didn’t see it. Same issue over and over.
Thank you in advance for any help/advice you all can offer. I’ll do my best to answer any questions as I really am a newbie with CNC.
Marshall
