Anyone have any ideas on how I could make this V carve tool path more efficient? I am carving with a 90 degree .5 inch V bit.
I am carving stars, i would like for the bit to just run up each point for the stars, but its making a ton of little lines in order to do it.
Are you trying to VCarve a 3D model.
The little lines are likely created due to nodes in each of the star edges. Edit your drawing to be sure there are only nodes at each end of the lines and it should clean up what you are seeing. VCarve is just trying to do what you are asking it to do. Post up an image of the vector you are trying to carve while in node editing mode.
