Continuing the discussion from Alternative limit switch mounting on Z-Axis?:
So as to be clear, Alan, it appears that you drilled a hole in the plate and inserted a screw/nut combination that allows the Z-axis to move just enough to trigger the limit switch but which does NOT allow it to move far enough to crush the switch. Is that right?
Any chance that fix will be incorporated into the design of the X-carve?
