Question on bit usage
If I go over this again with a 1/32 tapered ball nose bit it should just cut shallow lines deaper and not change anything else? I used a 90 deg vbit for it.DSC02519
You would need to add it as a detail bit, otherwise it will go over everything.
Somehow I didn’t get the Acme Screw all the way down it had a 1/4" play in it. Rooky mistake ran calibration tonight still have to do measurements but the cuts lookDSC02520 fantastic.
