I recently purchased a used XCarve 750X750mm.
- I would like to replace the waste board but am unsure if the clamp screws can be removed and reused… if so, is there a special tool to remove them?
- I would like to replace the Dewalt 611 with a spindle, preferably air cooled, any suggestions on a make/model?
- Are there any instructions on upkeep and preventative maintenance?
- Is there a program for resurfacing your waste board?
Thanks for your comments and help!
I’d imagine it is similar to this:
X-Carve Instructions: Work Area
You can buy a router bit for surfacing your work board and there are online programs to generate the g code.
Wasteboard Surfacing - LongMill CNC
Used VCarve and wrote my own resurfacing program… we’ll see how it works!
Hey I hope it worked well for you.
I have found that using vcarve pro and doign a .05 or .1 pass over the spoilboard works great.
Probably the easiest way to find a spindle that works is to take calipers to the router thats on it and see what size it reads.
You can also make a bracket to fit the spindle, that would fit the existing hole mounting pattern the z axis gantry.
I think I have an idea that’s not overly complex to execute if your interested.
I’m very interested!
Please!!
