Has anyone used a quick change collet on the Dewalt 611 router? What did you use and how effective was it?
Where did you get it from? The ones I see only reduce to 1/4 inch at most. Trying to get it down to 1/8th inch.
I bought this necklace in Amazon and I have a friend with a lathe and I managed it for 1/4 for the router and brought a complete kit for all kinds of bit that are exchanged?
Check the picture ?
JohanMotaFulgencio
That’s a simple solution obtaining extra cutting depth if you have raised your rails. ( which I have)
I will purchase ER-11 collets and adapt them as you have.
Such a simple solution
Thank you
Regards
Kel
BQLZR CNC C8-ER11A-100L Straight Shank Chuck Spring Collets for Drilling Milling Pack of 14 https://www.amazon.com/dp/B01K4IW1G8/ref=cm_sw_r_wa_apa_i_qbpCDbQ0RCBN2
Another advantage of this clamp is that I do not remove my dush shoe at all because I have my machine set to zero in the bed all the time in the upper left corner so I do not have zero point problems?
