Here’s all the info one may need:
The machine cut to the specified depth of .5mm for an hour then plunged down till the collet was in the wood making a straight diagonal path.
I have a 3018 pro and use easel to design and carve.
I just upgraded to the 20000rpm spindle (with the upgraded power supply), maybe that has something to do with it?
I check all screws and connections before every carve, nothing was loose.
I was running at 450mm feed rate, .5mm depth per pass, and a spindle speed of 14000
Any ideas on how this could’ve happened would be great. Thanks!
