Rapid retract
Easel added height settings for clearing clamps and so forth . Good stuff . Now could you add rapid retract to movements when z axis is to retract at any time .
Meaning if Z axis is for any reason retracting this movement could be at rapid rate. It is not cutting . At the end of the movement it would just return to the set feed rate . This could save a lot of time off program run times.
stay tuned :wink:
