Do the Inventables clamps shown in the attached photos look like red oak, white oak, or another type of wood to you?
Background:
I just finished carving/machining 2 extra clamps for my 2015 X-Carve out of red oak. After comparing my new clamps to the old ones (included with my original X-Carve) I noticed the grain looks noticeably different. This led to the two questions above.
Red Oak doesn’t always mean Red Oak, there’s True Northern Red Oak,Scarlett Oak, Pin Oak, Black Oak, and many others But once they hit the Saw mill their all just sawn and graded as Red Oak. The Ones you machined look to me like Northern Red Oak and the Ones from Inventables Look more like a Pin Oak or Southern Red Oak which tend to be more of a wheat color where Northern Red Oak has the more pinkish color and better defined radial grain
Debbie is spot on, any hardwood will do the job.
I have some made of cherry and some of oak. all have been in service for 4 years now.
I just threaded 1/4-20 into one end for jack screws for adjusting height, no need for inserts.
Baltic Birch Plywood here. Made them a year ago, even got the pattern from the projects page. Thicker ones are 7/16", and the thinner ones are 3/16". Never broken one, but have zipped through a few with the router. Use them almost every day. Doesn’t matter because they are cheap. Little left over rattle can marron to add flavor.
I’d be interested in trying the plywood clamps. I’ve made my own red oak versions over the years, but find they split really easy either when screwing in the threaded insert, or if accidentally overtightening.
Pike_lake, in case it helps, I machined the holes for my M6 inserts to Ø8.9 mm and saw no splitting when threading in the insert. This is only 0.1 mm larger than the Ø8.8 mm called out on the Inventables B25002 clamp drawing.
