Recommendation for Surge Protector
Good Evening,
I have my X-Carve 1000 with Dewalt router, my Shop Vac, and my laptop connected to a Tripp-Lite surge protector. I’ve been using this setup for nearly 6 years, but starting today, the surge protector has begun tripping in the middle of a couple carves.
As for a cause- I think maybe its due in part to increasing the RPM’s on the router, which I had rarely or never done til today.
I think the most practical solution here would be to just replace the surge protector with one that can handle a bit more juice? Does anyone have a recommendation for one?
Thank you,
Kevin
Learned some lessons :slight_smile: Apparently the load increase on the router was the straw that broke the camel’s back. It was a good run while it lasted.
I have some cuts that will cause more amp draw from the router, so the logical and simplest play here is to move the shop vac to a different circuit entirely (it draws around 11 amps by itself). Lesson learned.
