Here’s my latest blog post:
It’s been a busy summer, finally I’ll have some time again to work on cnc projects.
Good job . To think that was a scrap bit of wood to start off with. Many a person would have thrown that bit of wood away:)
Yeah I try to collect discarded pieces as much as I can!
Limbs are interesting to make — if you’re doing fiberglass then one needs to make a form and use a suitable clamping arrangement and hot box or glue setup — lot of needed gear, and then there’s tillering.
Bingham Projects is one of the main suppliers, but I don’t think they’ve expanded to CNC for that sort of thing yet.
EDIT: One interesting option is to just use some old skis for limbs — see the FITA book on making your own archery gear or instructables.com
I did try for a self-bow out of Ipê, but had issues w/ the joint at the handle — need to revisit that project.
thanks.
I really don’t want to go the ski route. Also no pvc or other cheap hacks.
I want it to be made as it should be, even though I realise my first try probably won’t result in a world class bow.
I 'm finding so much contradicting methods… Especially when using fiberglass. Some use strips, some use some kind of cloth tape. Very confusing…
For fiberglass you’ll want:
Lots of build-alongs for this — Sam Harper’s is good: http://poorfolkbows.com/glass1.htm
Yes, but the advantage of fiberglass is its lasting nature — I’ve got bows at home which are fiberglass which over 4 decades old — they shoot fine — an all-wood bow that old (and I’ve made a fair number) and shot as much as I would prefer to shoot (for a while I was up to every day) is either a broken stick, or a shot out wall-hanger.
I’ve found a source for limb fiberglass strips in Germany. The Bo-tuff I had already heard of but is very hard to find in Europe and all things considered too expensive in the few e-shops I’ve found it in.
