program cutting and gets almost done and computer states must reload then loses over half of the project that i was working on need help on why. thanks Joel
Reload what?
What was the exact message?
I’ve been getting an error that says " this file has been modified by another instance of Easel. if you wish to save, make a copy"… or something to that effect
you will get that message if you work in that file while it is carving. You can open and work on other projects but you need to stay away from the one that is actually running. Had it happen to me before. I went to look at a cut depth after it started and changed it accidentally and got that message.
That makes sense. I have been guilty of that
