Remove spindle plate, add generic plate, Mount JTech laser
Good Morning folks, as the title states, I want to remove the router spindle plate/mount and replace it with a Gantry plate that I can mount the JTech 7Watt Pro laser on permanently; turning My X Carve into a laser only CNC.
I see that Inventables has a carriage plate for sale for $8.33 that should suffice however, they want to gig me $20.35 for shipping?! Thanks, I’ll pass on that. I have been perusing OpenBuilds website (they’re 45 minutes from my location so shipping would be considerably less) and came across these plates but, am unsure which one to try: https://openbuildspartstore.com/openrail-gantry-plate/
It looks like I might want the 40mm plate which is one of 4 plate options they offer but I’m unsure. Does anyone have experience trying this or something similar?
Any advice on this endeavor is much appreciated, Thanks!
Could you remove your existing plate and measure the screw holes behind to detmine the spacing?
lol, I was out there removing it and measuring and came back in and saw your post. Here’s some pics:
It looks like 20mm spacing on the screw holes for mounting the plate to the backlash block on the ACME screw and 80mm between V- Wheels vertically and 65mm side to side (center of wheel holes).
Oh well, OpenBuilds plates are in-compatible with the MakerSlide. I guess I’ll have to bite the bullet and take the rectal stretching on the shipping price. :rofl:
ETA: I’ve since discovered that on the final page at checkout, you get the option to use usps which charges way less to ship (4-6 day delivery window). I Guess the most expensive option calculated by default on the first cart page. Anyways, no $20+ shipping fee after all.
Why not drill and tap the existing plate?
I thought of that to but i believe they are aluminum so if it is a magnetic mount it will not stick unless you add some steel.
Because the Spindle mount is part of the Gantry plate. Thus, I ordered the flat plate from Inventables to replace it and I will be Mounting the laser on it, not using the magnets.
