Hi there,
I’m new to Easel and X-Carve pro.
Is there a way to repeat carves without doing a probe each time?
Thanks
Markus
Hi there,
Thanks
Markus
If you use the same size material and same location on the wasteboard you just tell easel to “Use previous” when the probe screen appears.
Yes. As Robert said, you can just tell Easel to use the previous settings for your workpiece. However, if you have turned the machine off, I would absolutely recommend Homing and check your work zero again. It can absolutely change with a power cycle, and I have seen it multiple times.
I like to drop the z manually into the workpiece at XY zero if possible to make a mark that I can find again if anything goes wrong. Different machines do different things, but if you can line up with a starting ‘hole’, it sure does help.
