I was trying to create an SVG model, but the letters were coming out odd. I created new letters to replace them in Easel Pro using letters I created from the toolbox. I have inserted the new letters into the model but can’t remove the old letters from the model.
To basically ungroup a grouped design element you can use the shape exploder app which can be found by clicking the lego looking button on the left.
There are 2 similar apps, one called shape expolder and another called Xploder, try both im sure one will generate the reaults youre looking for.
You can then select the design element and edit>remove (or just press backspace/delete)
