Would like to give you heads up on a couple of issues that I came across. In Easel if you grab a text box you can’t hit “backspace” or it will reload the page. Also I do not use a free day on pro very often but I have noticed if I have to select “use a free day” once that participial piece is done cutting I load a new program and try to use it again and I have to “use a free day again” it is fine with me since I do not use it that much but if someone else is using free days more often then they will burn them up quickly.
Hi @MikeHolden! I checked in with our team and they would like you to reach out to our Customer Success team so they can look into the issue you’re experiencing!
