Request - Warning dialog before carving when cuts are smaller than selected bit
Ie, if the bit is 3mm and some cuts in the design are 2mm display a warning that the bit you are using will skip these areas.
There use to be a feature…if the bit was too large for smaller areas of the design, the preview would indicate areas that wouldn’t be cut by the too large bit by highlighting portions of the design(in orange or red) that might not cut properly.
Just now, in verifying this, it seems that the preview now only shows what the cut will look like with the select bit size and doesn’t show what will not cut.
Interesting… is seems that a new feature that is cool has overridden an old feature what was useful
