Is it possible to have the time simulation and tool path reset when making changes to the cut settings. Right now you have to make a change an object in the project for the simulation to reset.
You can click on the Fill or Outline setting and that will clear the simulated time and you can then re-select the Simulate feature.
Yes I know, but it should reset anyway when you change cut settings because it effects carve time.
Thanks though!
I’m not near a computer at the moment, but can’t you click the carve time to recalculate the toolpath?
Not once it has been run once. Seems only changing an object will reset it.
Bizarre… I am sure this did not work for me on Friday.
Anyway thanks for making me try again , will try it shortly.
Enjoy your Sunday!
