not sure that this helps, but what I do is combine items after doing the rotation, then you still have the history and the ability to undo any changes…
I understand what b your saying & I agree with you. What I am showing is that combining is just another work around to closing and reopening the project.
If you rotate and then combine (I used a 0 depth object to combine as a trick) then it will re-assign the height and width to their proper directions
