When you go through setup, you check the direction of the axes. You say yes or no to the direction.
You can change these settings by
Going into the Grbl Settings and make the change.
It would be the $3 setting If you Enter $3=4, that should reverse the Z only.
Xcarve GRBL settings - X-Carve - Inventables Community Forum
