Somebody out there in Rochester, NY willing to come and help me. I can’t out whats going on with my carves. Machine is square and the z axis is square.
Offering beer and a couple chuckles.
Can you describe what the issue is? Maybe post a short video of what is happening?
I can’t offer in-person help, but I could possibly jump on a Teams, Zoom, Discord, or other video call one afternoon or evening. PM me if you want to try and set something up.
{:0)
Brandon R. Parker
Yep so we’re a 16th off in both the x and y axis. Its also didnt reach full depth and along the x axis lost the depth completely.
Definitely follow @SethCNC’s advice above for calibrating the machine and choosing “Cut outside shape path” on a cutout.
Also, if you are losing depth across the X-Axis direction and this loss of depth is the same at different Y-Axis points, you could have further issues:
If the machine components are set up correctly, you can run a wasteboard flattening design to correct the wasteboard thickness variability. Technically, this would work for #1 as well, but it is best to get the machine itself set up as closely to perfect as one can and then flatten the wasteboard.
{:0)
Brandon R. Parker
