Greeetings Folks ,
I am trying to round the corners for the inner square, any tutorial will be greately appreciated.
Cesar UNIKO GT
Can’t you use a larger diameter router bit for that outer pass?
Can you use the corner radius and just set it to what you want?
Thank 's Martin I will try.
Hi Wayne can you tell me where to find the procedure ?
Highlight the pice you want to round the corners on then click on the shape button up on the right. That should get you to the cut page and down toward the bottom there is a radius button for the x an y axes.
