Hello, I have a project which would look better if I used a round over bit to finish off the top of the project. Does anyone know if this is possible with Easel, if so, how would it be set up. Many thanks
Dave
It is possible, you’d enter the bit as the center tip diameter , set the toolpath to inside or outside the path depending on the project… and thats it, well adjust cut settings for stepdowns and feedrate as needed of course…
The tip diameter on this one is just about 1/64"
https://amzn.to/3BIF21b
I think you want to cut “on path”.
If the tip comes to a true point, yes, if the tip has a width then the width would need to be accounted for by riding inside, or outside the path by that amount… for example this one has a more pronounced tip diameter that would need accoubted for…
Hi, thanks for the reply, I get it now. Many thanks
Dave
