My machine stopped mid carve router didn’t return to starting spot and progress showed as carve complete. How can I get router back to starting coordinates to start carve over. Thanks
Tarski
What machine do you have?
{:0)
Brandon R. Parker
A Millwright Carve King 2
Thanks
Does the machine get stuck, or can you move it manually with the controls after this occurs?
The most common issues that can cause this are:
- USB cable issues.
a. Route the USB cable away from the spindle power cable and any other source of RFI.
b. Replace the USB cable with a quality shielded cable. - Windows USB port settings that put the ports to sleep after a certain time.
https://hisnhershandcrafted.myshopify.com/blogs/the-blog/how-to-disable-usb-selective-suspend-and-stop-your-cnc-carves-from-failing-prematurely - Issues with the physical USB port.
See if any of those things resolve the issue. My bet would be on #1…
{:0)
Brandon R. Parker
