G’day. Silly question - when setting safety height and return height, is it measured from the tip of the bit installed? does it then calculate according to the Z setting when the job starts? Thanks.
Those are in relative to the Z work zero you establish before you start a job.
Thank you. that just soleved one of my long-term problems - someone had fiddled with both settings🥺
